If you are going to change the fronts, then I would suggest you try and stick with a center that is timbre matched. The surrounds do not have to be matched, but if you were to go and get a whole setup, then it might be best to go with the same brand. But it is not a big deal. Heck I have Boston VRX's as my surrounds and Swan 6.1's as my fronts and Swan C3 Center. I got the Boston VRX's for a steal and sound good with the rest of the system.
- Garrett
- Garrett
