BTW, there's this.
Set the gain on both subs to the same level - around 12:00-2:00 on the gain knob is a good starting point (just a starting point, gain structure can vary greatly from one manufacturer to another). Set phase to "0" on both subs for now.
1. Connect sub
#1 only and place it at the MLP
2. Do the sub crawl to determine the best position for sub
#1
3. Place sub
#1 in that position
4. Connect both subs and place sub
#2 at the MLP (with sub
#1 playing as well)
5. Do the sub crawl to determine the best position for sub
#2
6. Place sub
#2 in that position
7. Playing the AVRs test tone, adjust phase on one of the subs until you get the maximum SPL at the MLP (could be variable or a simple 0/180 switch) (if you have SubEQ HT, skip this step)
8. Run Audyssey, first mic position only, and "calculate"
9. Look to see where Audyssey has set your sub trim, you want it to be around -6db to -8db ideally
10. Adjust the gain on both subs
by the same amount up or down as needed
11. Repeat 8-10 until you get the sub trim around -6db to -8db
12. Run the full Audyssey calibration
13. Set all speakers to "small"
14. Set all crossovers to 80hz (or, if set higher than 80hz by Audyssey, leave them alone)
15. Bump up the sub trim by 3db to 6db to your preference
16. Enjoy!
Hope this helps!
