Status
Not open for further replies.
1 - 5 of 5 Posts
It is 9 3/8 inches tall and 22 1/2 deep (sure you know 130lb) Manual says 12 inches above for air flow.
P5 is 340 watts at idle, D1 is listed at 140 max, I find mine is pretty warm running. From the picture cant tell if the back is open or not, and if it is that would help some, but it looks a little tight to me.
Hope you enjoy the pair, I have been very pleased.
Discussion Starter · #3 ·
If the back is not open I would cut an opening to help with air flow. Would I risk damage and void the warrentee if I decided to go this route?
If you cut a 3 or 4 inch hole in the back you could always put a small muffin fan from Radio Shack in there to pull out any hot air. That should more than fix any ventilation issues
HTH
-Joe
Discussion Starter · #5 ·
HTH
-Joe
Interesting... that sounds perfect actually. Thanks for the tip :)
1 - 5 of 5 Posts
Status
