Status
Not open for further replies.
1 - 12 of 12 Posts
I have had my Dish 6000 for 3.5 years now. Recently the OTA module had gone on the blink. It was just displaying mostly GREEN pixellation on local channels.
I noticed that alot of dust had accumulated on the circuit board due to the fan. I took the module apart by removing the nut on the 75 Ohm connector, removing the screw on the same plate, and removing the metal circuit board cover. I vacuumed off the circuit board very carefully.
Voila! It fixed the problem.
Discussion Starter · #3 ·
I had at one time fixed a problem with a computer switching power supply by vacuuming the dust out of it. That's what gave me the idea of vacuuming off the dust from this card. There are many high frequency signals on that card that the dust could be interfereing with. The dust also impedes the removal of heat from the chips on the board.
So let me get this straight, you had the Same Dish 6000 for 3.5 years? Now I know you are making this up. ;)
Seriously, I've been wanting to clean up my 8VSB, but I didn't know to do disassemble it. I didn't try the nut on on the RF connector. I'll have to check it out.
Discussion Starter · #6 ·
I have had my 8VSB module to start pixelatting before because of overheating when the fan was removed. I just reinstalled the fan and it started working. It may have been because of dust that had collected on the chips on the board.
I know you cannot put anything on top of the 6000 when you have the fan removed.
If you also have the 8psk module installed, DO NOT leave the fan out unless you use some form of auxillary cooling, i.e. small fan blowing on the box where the modules are inserted or you will have all kinds of issues. Trust me, been there, done that.
Okay guys maybe this will help me with my OTA problem it just stop working when I hook my antenna up through the 8vsb I get no digital stations picked up and the analog stations that I due pick up don't show anything but noise. When I go straigth to the tv with the antenna the analog channels come in clear. Could this be caused by dust?
I've had the 6000 for about 3 years and the 8vsb for just about as long. Because of the noise, I immediately removed the 8vsb case top with the fan, and have had no problems since.
Discussion Starter · #10 ·
Richard,
What kind of antenna are you connecting to the 8VSB module?
Have you used the Add Digital menu item to align the antenna with the desired digital station?
What you are describing does not sound like a dust problem. I was getting green pixellation on both analog and digital channels due to dust.
The antenna I'm using is one from Radio Shack can't remember name or number I have used the add digital to no avail I think it may just be the module. Would it be worth it to try and have it repaired? I know they are still asking $150 for a new one.
1 - 12 of 12 Posts
Status
