Status
Not open for further replies.
1 - 2 of 2 Posts
I have an hs10 and want to buy a dvd player (I think), and have read alot about gamma correction and how the rp82 doesn't have it.
how important is it, considering the difficulty lcd projectors have w/ blacks?
thanks a ton,
Rob
PS: any other dvd players w/ as high a quality picture, with gamma correction, that are less than 350$?
Your projector may have the ability to change the gamma settings in it's menu(s). If so then you would not have to worry about the DVD player having it. Check the projector section to see if it has the ability.
1 - 2 of 2 Posts
Status
