Originally Posted by JThiessen /forum/post/0
Refresh me - whats LCR?
LCR means Left, Center, Right
And when someone refers to front speakers as LCRs that means three Identical speakers. Not a dedicated horizontal center, that maybe way smaller w/smaller drivers.
I use 24" tall LCRs, but being I have a 65" RPTV means having the center speaker below the screen, which is lower than the L/R that mount to 19" tall subs. So my setup is not perfect, but the speakers are Identical. And the center is tilted back to make up, in part, for being lower so the drivers are pointing to the ear level.
Originally Posted by bulldog21 /forum/post/0
How are you able to tell if the timbre matches?
Put on a movie that has a lot of action going front to back, side to side, as with car chases or jets flying overhead.
As the sound goes from speaker to speaker, if the speaker's timbre is not a match, or at least close, then you will hear the sound's voice or timbre change. Maybe from low to high, or smooth to scratchy. Or what have you.
Of coarse having 5/7 identical speakers is a must for DVD-A or SACD multi-channel music.
