Originally Posted by Roshy /forum/post/20819227
I'll probably stick to mounting it 8 feet in the air then so it (so top of the screen). I read in various places not to put the screen closer than 1 foot to the ceiling, is that also correct?
My budget? I don't really have a specific budget. I was assuming I'd have to pay around 2000ish. I'll pay more if it is really worth more, if I don't need to spend 2000, that's great too. But my estimate of 2000 was just looking at how much various screens cost, not knowing their pros and cons.
Thanks for your help!
If possible, I would go with a fixed frame screen. The next decision has to do with what you watch and the size of your room. If you watch a lot of movies then I would consider a 2.35 screen as long as it works in your room with regards to speaker placement. If you watch a lot of 1.78 (16:9) content (HDTV) then I would go with a 1.78 screen.
If you go with a 2.35 screen, that means you will be using the motorized zoom so that you can change the size of the image. In other words 16:9 content will be shown on the center of the 2.35 screen with gray bars on each side. 2.35 content would then be zoomed so that the image fills the whole screen by dropping the gray bars off the top and bottom of the screen. This means that you will have to use the zoom anytime that you change between the aspect ratios.
The other option is to get a screen and add a masking system to it later. For this you need to plan carefully. I use a horizontally masking system and I really like seeing nothing but image when I am watching movies.
If interested in movies and wanting to do the zoom method, take a look at the Dalite Cinema Contour screen with Cinema Vision fabric. For a masking system, some use panels and or curtains. There are some companies that make specific masking systems, but these are expensive.
