All right, I have an extremely small room for my projector. About 10 feet by 12 feet so it doesn't take much to heat the room up especially when you get 2 or 3 people in there. I was wondering if 100CFm would be enough to suck the hot air from the projectors exhaust and blow it out the window using 4 inch ducting at roughly 12 feet long? I have done it with 200CFM fans, but they are very loud at about 50Db/A. I found a couple of fans that move about 100CFM at 20Db/A that are much quieter, I am just not sure if 100CFM is enough or not.
I am running an Optoma HD66 projector.
Thanks in advance!
Thanks in advance!
