I have 2 18" round dishes, one pointed at 101, one pointed at 119. All 4 leads from the 2 dual lnb's run to a multiswitch. The multiswitch is grounded. The 4 outputs of the multiswitch run to one side each of a diplexer. The other side of the diplexer has cable run to it. The diplexers then run into the house and other diplexers that go to the sat receiver and coax cable input on the tv as appropriate.
Because the multiswitch is grounded, do I need any other grounds in this setup, e.g. grounding blocks, etc?
