You may and probably will get differing opinions, but make no mistake about it if you are not pushing it to the max you may as well have spent less and settled lowed or spent more and settled because you're lazy.
A 7" can beat a 8", an 8" can beat a 9", a 5.5" can beat a 9" given a whole hell of a lot of work and fresher tubes, though sure, good luck trying.
Part luck, part bandwidth, part phosphor size, part skill.
What order, I dunno... Luck is good, But it helps to have more on your side than even just skill.
Troy
Troy
