Status
Not open for further replies.
1 - 2 of 2 Posts
I have been curious about how much information is actually contained on an anamorphic widescreen DVD and I think I have the answer:
- DVD's have a resolution of 720 x 480
- With a letterboxed format of a 2.35:1 DVD, the picture would therefore be 720 x 306 with 174 lines devoted to the black bars on the top and bottom (= 87 lines/bar)
- An anamorphic DVD stretches the picture vertically by 33%. This results in an image 720 x 408 with 72 lines devoted to the black bars (=36 lines/bar)
- Therefore there are 408 lines of horizontal information
- With an 800 x 600 picture in a 2.35:1 format, you can display 340 of the 408 lines (800 x 340), a loss of about 17%
- With a 960 x 540 screen, you can just display all of the 408 (960 x 408) lines of resolution.
- Going above a resolution of 960 x 540 should not buy you any additional sharpness (although you can get other benefits such as less screendoor) because at that point you are merely scaling up the image to a higher resolution.
Can you get a 16:9 anamorphic DVD? If so, then the letterbox version would be 720 x 405. The anamorphic version would be 720 x 540. An 800 x 600 projector could display 450 of the lines and again a 960 x 540 projector could just display all of the 540 lines.
Your math seems about right for USA and Japan DVDs. For UK and Australia, DVDs are 720x576, so you need 1024x576 to not lose anything.
1 - 2 of 2 Posts
Status
