First post here, I've been lurking for a couple of weeks as I begin my dedicated theatre construction. (I'll make a thread soon)
My room is 272.25" x 136.25" basement room with a partition wall framed in for the screen 44" off the long dimension. I do have a terribly low ceiling at 80", but there is no way I'm messing with it (walls and floor are poured concrete, as some people in 1946 feared nuclear war. The cool part is I should have excellent sound isolation. So far I've only got the studs up and wanted to take 2 weeks to read before making errors. This place has been helpful!!!
My Question:
How much viewing angle can you take before it becomes a negative? Let's ignore resolution issues unless that becomes a negative before screen width...I'm not sure which is an issue first with a good setup. I know THX recommends 36degrees, and a minimum 26degrees, but I've read a thread here where some had 50+degree front row viewing angles (the 2.40:1 screen thread). I'll likely run a 16:9 screen, but may even do 4:3 since I'm width limited, not height limited in terms of the screen. I want to do a custom tiered couch rather than berklines, with some bean bags up front and some driving simulators for PC games in front of the couch. My concern is the 53degree or so angles in front of the couch will be too much with my couch front row at about a 38 degree viewing angle. I'm expecting my screen to be 95" diagonal.
I have links to all the calculators. I'm looking for your own real world opions on this issue.
My Question:
