Simply apply the Glossy White paint by either rolling or spraying (preferred) until the surface is evenly covered and wholly opaque.
If you spray, the paint need not be over a Primer coat unless the Primer is needed to make the underlying surface suitable, either by improving adhesion, smoothing the surface, or both.
Many own to using Gliddens Gipper Primer on surfaces like Melamine coated Hardboard (TWH) and to do so isn't a bad idea, especially when one is rolling. Heavier rolled coats tend to lift off a slick-ery surface. Dusted=on initial coats allow the "spotty" coatings to dry fast and act like little grabby hand-holds for the subsequent later coatings.
