I would like to mount a 52 inch TV above a gas fireplace, but there is a deep nook above my fireplace that's not wide enough to fit the TV. I don't want to put drywall up to eliminate the nook because I would like to use the nook to put my PS3, router, and eventually a reciever. I haven't measured how deep the nook is to give you a better idea of the the depth, but is there a mount that provides a longer arm to facilitate deep nook installs like this to allow the TV to be positioned infront of the nook?
For somewhat of a better idea of how deep the nook is, it used to hold a 32 inch standard def TV.
Edit: the nook is about 28" deep.
Okay, I've finally taken time to add pictures. I think mounting an Omni Mount UCLXB to one side in the nook and then allowing the arm to swing forward should be able to center the TV in this nook.
The dimension of the nook are:
28" deep X ~49" tall X ~40.5" wide
My wife and I are hoping to get tho whole area around the fireplace cleaned up totally emliminating the entertainment stand and putting the PS3 and a future receiver in the nook behind the TV. Does this sound like it will work?
