1 - 12 of 12 Posts
I recently purchased 2 custom subwoofer cabinets (SEALED) with 2 18 inch drivers in each of them and a single pair of binding posts. This leaves me with the option of a 2 ohm or an 8 ohm load. (4 ohm drivers)
After assessing how expensive it is to run 2000+ watts into these loads, I was thinking of going with inuke6000's with 4 ohms on each channel, one for each cabinet.
Now the speaker plate looks something like this and is screwed into the body creating a perfect seal:
https://www.parts-express.com/squar...1-8-satin-nickel-banana-binding-post--260-312
Does anyone have any experience on drilling small holes for a second set of wires, then somehow sealing those new holes? I assume they don't make a plate with 4 binding posts that is identically this size, they all seemed more rectangular. So a DIY hack sounds like my only option.
easy, take off the terminal cup, then glue a piece of MDF inside the cabinet righter where the cutout its... that makes a recessed hole with an mdf "plate" in there. then just use a 1/4 inch drill, drill two holes in that and tap in these. http://www.parts-express.com/dayton-audio-bpa-38g-hd-binding-post-pair-gold--091-1245
then just tighten them down and voila.
Discussion Starter · #3 ·
Hey, thats a great idea :D. Couldn't I just drill holes in the plastic plate and do the same thing?
I wouldn't.. easy chance of cracking the plastic, plus they're made to be just a HAIR bigger than 1/4 inch drill bit, thus making it create a seal when you have to "tap" it in... don't think that would work with the plastic very well.
Discussion Starter · #6 ·
also, why do you need another set of posts if you already have that terminal cup?
Well I don't necessarily need "posts" but a way to get a second set of wires outside the cabinet so I dont have to wire the woofers in series or parallel.
Perhaps I should just drill 2 small holes in the cup to allow 12 guage wire to fit, and seal it with something.
Premium Member
If you use an amp that can be bridged (I forget if the 6000 can be), wire for 8 ohms and you'll only need the 2 terminals.
8 ohms bridged is the same load on the amp as each ch driving 4 ohms.
Discussion Starter · #9 ·
Unfortunately the 6000 cannot be bridged :(
I've decided to go with a Crest Pro-lite 5.0 as this can be had for the same price as 2 Inuke6000's.
Discussion Starter · #12 ·
If you do some searching I've seen the crest 7.5 as low as 899 from authorized crest dealers. May be unnecessary, but you are in AVS DIYLand
via Tapatalk
I ended up getting a Pro-Lite 5.0 for $649. I am very happy with that. :p
1 - 12 of 12 Posts
