1 - 7 of 7 Posts
I haven't been able to reach anyone in their tech support department, any idea how to adjust the drop of the screen? I know there's a way to adjust something inside the case, but can't find it on their website?
Look on the back of the casing near the power cord. There's a gap where you can see into the casing. There's a white and yellow screw. Your gonna need an allen wrench. You wanna twist the yellow one clockwise about 3 or 4 full rotations with the screen up. Then lower the screen and if it's to high just simply turn the yellow screw counter-clock wise. The easiest way is to adjust it to high, then lower the screen and readjust it to how low you need it. Hope this helps.
Originally Posted by Cham313 /forum/post/19632986
Don't depend on color (Elite is inconsistent with colors for these adjustment screws). See my posting in the official Elite thread:
http://www.avsforum.com/avs-vb/showt...4#post19422414
Hey Cham313, thanks for the tip! You are absolutely right, don't depend on the color! I hooked up my Cinetension2 today, read your comments before I adjusted the drop. Had I depended on the color, I would have probably ruined the screen. Mine had the yellow screw in the back of the screen, and the white screw toward the front. To adjust the vertical drop, I had to lower the screen and turn the WHITE screw clockwise (1 turn per inch of adjustment). Worked like a champ. Thanks again for your post!
Sorry to bring up an old thread, but does it come with maximum drop from the factory? I just put mine in my ceiling and umm uh oh... It's a bit high... Answer found. Damn.
1 - 7 of 7 Posts
