I have a 50HP16 Toshiba Plasma and I recently put my Xbox 360 on the VGA input. The colors looked very washed out so I bought an AVIA DVD to calibrate the white level, black level and the RGB settings.
Ive successfully set the brightness/contrast to my liking, but now I'm trying to figure out the best way to set the individual R,G,B settings that the VGA input allows me to change. If I use the "Blue Color Bars" chart and look through a blue filter, changing the R,G or B levels seems to have negligible impact (I don't see any flashing boxes.) This is also true if I use the "Green Bars" or "Red Bars" charts looking through their respective color filter.
I guess what I'm also asking in addition to how best to calibrate RGB is what exactly am I changing when I fiddle with the R,G or B settings? It appears not to be hue or saturation based upon the "Blue Bars" test, perhaps this is changing how the TV does color decoding? Ive tried the color decoding chart and I do see changes in where the 0-point is when I move the RGB settings but it's pretty minimal. For most of the colors, I feel in order to get to the 0-point I need to be able to go above the max of 50 for the RGB settings that the TV allows. Ive gone into the service menu and I notice there are options for R Drive(N), G Drive(N) and B Drive(N). I didn't want to change any of these without consulting experts on this forum first as "drive" leads me to believe this is going to mess with voltages, which set correctly could do permanent damage to my TV. Any help and insight on this would be much appreciated. Thanks!
