I'm right around 3x screen height for scope and think it's great... 50" Height / 128" Diagonal at a little over 12' viewing distance. I think 2.5x would be the max I could go comfortably and 2.7x might be the sweet spot... I would love to do so, especially for a little more 16:9 size, but I have both width and height limitations due to an outset wall bump in the front of the room, pitched ceiling, and a cap on throw distance.
Prior to going scope, I had a 106" 16:9 screen (again, due to the front height restriction. I had to give up my B&W towers and center speaker and go with in-walls behind an AT screen to make room for scope. Even if the speakers had ended up being a downgrade (I already had Sonance Cinema .5 THX-Select in-walls behind the screen from a previous DIY Spandex AT screen), it would have been 100% worth it for the added immersion. Luckily I was able to upgrade the Sonance in-walls to Monoprice THX-LCR Ultra in-walls and keep top-notch HT sound quality along with the scope screen upgrade... the only downside is they're not quite as enveloping for 2ch music listening and required the addition of a 3-channel (Emotiva XPA-3) amp due to my Marantz AVR getting extremely hot driving the 4ohm (3.2ohm dips) load (even in 4ohm mode).
Silver Ticket WVS 125" 2.35:1 Acoustically Transparent Screen Review • Hardware Reviews • Home Theater Forum
www.hometheaterforum.com
Home Theater Forum • The Monolith THX-LCR In-Wall THX-ULTRA Speakeris is a capable hometheater-focused speaker with excellent dynamics.
