Status
Not open for further replies.
1 - 4 of 4 Posts
Hi there,
was wondering if anyone could help me...
I have a Panasonic TH - 42PW7BX panel.
I want to buy a Hush Windows Media Centre which has DVI out. But, the plasma doesn't have DVI in.
I currently connect to the plasma using RGB Scart.
Is there a converter out there anywhere that will convert DVI to Scart to allow me to use the scart connection on the panel please?
Many thanks
Trevor
If your model is anything like the US model, you should be able to get an adapter card that plugs into the TV in a spare slot (you'll see these referred to as a "blade" on the forum) that will take your DVI connection. Check with a dealer.
It's inconceivable that there would exist a DVI to SCART adapter, but I am not 100% certain.
As maryj19 said, for the US model there is a DVI card that could be inserted into an open slot to provide a DVI digital input. I don't know if said card will work with the UK version.
As I understand it, scart is analog, so a DVI digital adapter is not possible.
1 - 4 of 4 Posts
Status
