1 - 5 of 5 Posts
I am new to home theater systems. I already placed ordered for speakers and sub. I am placing order for cables. I don't know which cables are required to connect the sealed F15 subwoofer to Marantz SR5007.
I will have a 5.1 setup. I will be connect my AVR to my PC using analog input as well as TOSLINK. I will switch between them depending on application.
How do I connect the AVR to the sub? I was thinking pre out SW1 should be connected. But the sub back panel shows lots of inputs that have both L&R and some outputs. There is no single sub in.
Pics below.
Super Moderator
According to the Quick Guide (PDF) for the PEQ3 amp that's included with the sealed subs (including the F15):
Line Level inputs
. . . For sub output from HT receiver/processor, one can use either of the two (R+L) line level inputs with AVR/12* LOW PASS switch ...
(*On the newer amps, this appears to be labelled "EXT/12".)
Discussion Starter · #3 ·
I was searching in amazon for cables. When I searched for subwoofer cables I found a long RCA cable with a Y splitter. I was confused because of the multiple inputs and outputs on the subwoofer. I guess I need to connect the subwoofer cable to SW1 and then to the Y cable which goes into L&R in of the subwoofer. Such complexity should have been replaced by one cable that goes into Subwoofer IN.
With your post I was able to figure out what goes where. Thanks!
Super Moderator
... I guess I need to connect the subwoofer cable to SW1 and then to the Y cable which goes into L&R in of the subwoofer.
FYI, I updated my previous post - because I found the Quick Guide on Rythmik's website - to reflect the fact that you only need to connect to the L or the R input.
BTW, congrats on the new sub!
I'm curious to read your thoughts on it. (I almost ended up with dual F15s a couple of years ago.)
The left and Right inputs on the sub, allows the 2 channel crowd to connect the Left and Right pre-out to the subs Left and Right inputs of the subwoofer
Originally Posted by AdithyaG  /t/1469178/how-to-connect-rhythmic-subwoofer-f15-to-marantz-avr#post_23226731
1 - 5 of 5 Posts
