Hi all,
How can you display anamorphic DVD using HTPC to feed to a LCD projector? Mine is NEC MT1045
Do you have to use yxy to squeeze the image vertically?
My other question is: in the PowerDVD/WinDVD, there is a button call "keep aspect ratio". If I click this, is it going to remove some horizontal lines to correct the aspect ratio? (just like the way DVD player works?)
Thuan
Thuan
