This is more along the lines of the Monty Python sketch, "How To Do It" where one is taught to play the flute by "Blowing in here and moving your fingers up and down here" or some such like.
But in searching through the myriad forums here it is clear there is a tremendous desire to record hi def programming and make it portable, i.e. unencrypted and not tied to one machine. Although a capture card with component inputs is one possibility, the signal is no longer digital.
With HDMI, the signal is all digital, but encrypted end to end. But what about the end? What if, instead of, or in addition to, it turning on and off pixels in a flat screen, the decrypted data stream were captured? Would it not be possible to use that record to make the pixels turn on and off exactly as they would have with the live feed?
In other words, put a sniffer in between the flat panel's internal connector and the ribbon cable (if there is one) from the chip in the TV that has decrypted the signal. Isn't that data, which is creating the picture pixel by pixel, identical to the program data before it was encrypted by the cable company?
And if it is, might there not be a way to intercept that data as the signal is fed to the screen?
So, unless there's something of which I am unaware, here's how to do it: just intercept the signal as it's fed to the panel and record it on your hard drive.
Next we learn how to split an atom, how to construct a box girder bridge, how to irrigate the Sahara Desert and make vast new areas of land cultivatable, but first, here's Jackie to tell you all how to rid the world of all known diseases.
Paul
Paul
