Originally Posted by sabex /forum/post/9520411
I am looking to install an antenna in my attic.
What sort of meter can I purchase or ,better yet, rent that will allow me to check my signal strength without incessant trips back and forth to the living room?
I have seen satellite strength meters but I am not sure that would apply for OTA UHF signals...
Simple solution. No fancy-schmancy and grossly overpriced electronic gizmos are needed, nor do you need to pay someone to install it. You only need a good compass and the antennaweb or tvfool website. If you know your antenna beamwidth pattern, determine the bearing to which you would need to point the antenna to maximize the number of channels to be picked up. If all of them are at the same bearing, it's easy. If multiple bearings that exceed the antenna beamwidth, then you may need a rotator.
You use the compass to determine the azimuth pointing angle. Be sure to keep the compass away from ferrous metals like the mounting pole when making azimuth measurements, else the compass can point the wrong direction and throw you off angle.
I did this one time when installing my bowtie outdoor antenna and got a near-perfect signal level on the majority of my local transmitter towers. Didn't have to go up/down/up/down/etc........The signal strength will vary from one station to the next as the power level sensed by your ATSC receiver varies with the output power of the channel at the source, the gain of your antenna at that specific frequency, the range from the tower, and the frequency response of your coax line. All of this is assuming that you have a clear line of sight between the towers and your antenna. You don't really need all of that over-priced stuff to align onto the towers in your area. Yeah, I know, you want an attic install. The same principal holds, but I recommend using the compass outdoors so you can get a bearing of where you need to point the antenna in the attic. Most OTA antennas aren't that sensitive in beamwidth, like a satellite dish.
