Status
Not open for further replies.
1 - 1 of 1 Posts
Currently I'm using the Skyworth via VGA out into my Cine7. I noticed that the red is quite saturated. You can try to adjust the red cut but it will not solve the problem completely. But when I set the temperature setting to 9300K instead of 6500K, the saturated red disappeared but a very very slight tendency towards bluish. Of course you can easily correct this by turning down the blue gain. This has worked perfectly for me, try it.
1 - 1 of 1 Posts
Status
