Personally, I'd lean towards keeping the discrete channels of SACD as is, since in some cases you have 4.0, 5.0, 5.1
Originally Posted by sdurani Ben, Some receivers will automatically output each surround channel through its respective side and rear speakers. On other receivers, the sound only comes through the side speakers while the rears go silent. Have you checked to see how your's works? If your receiver has 7.1-channel analogue inputs, then you can use Y-splitters on your SACD player's surround outputs so that sound comes out of all four surround speakers for a more enveloping sound. Best, Sanjay |
Originally Posted by bhorrell Does splitting the signal decrease the level of that channel? |
Originally Posted by barhoram If one wanted to keep the SACD or DVD-A 5.1 channels, which of the 2 back channels (rear or side) would be used? |
