is the picture going pass the edge of the TV, well thats overscan and its normal
but ATI has had overscan adjustment in their drivers for ages
I would suggest using the 1776x1000i setting
it might not fit perfectly but should be close, and overscan is normal for TVs
all TVs have overscan, the newer microdisplays do have less though
and then the waviness is the geometry of the tube, call a Sony service center for repair if it bothers you
