1 - 4 of 4 Posts
I want to modify a CNCAMI module to increase it's "pre-set" capability from 6 to 49. Can it be done?
Discussion Starter · #3 ·
Originally Posted by jdanforth /forum/post/19607833
Yes it can be done. You have a CAMI in your house?!?
Yep actually 2. Soon to be 10. One for a camera that is modified for outdoor use. One as a spare and the other 8, well if I told you I'd have to kill you
I have already modified the module for 50 presets. Eventually the other 8 CPC-CAMI's will be modified for outdoor use. I don't know if you've ever worked with them or had one apart but they are wicked strong and well built. The weak point is the interface but if it's remote mounted and the motor assembly sealed will work outside all year long. I've proved that with the first one.
I'll give you a clue. It's a solar experiment.
1 - 4 of 4 Posts
