Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally posted by gusx Thanks for the advice. I'll probably end up getting the sony mount ... it seems to be the easiest solution. |
Originally posted by BugMan74 Unistrut huh... That's looks like a much better solution than what I was designing! Is it available at general local hardware stores? |
I see it makes it able to adjust side-side, and front-rear, but what about tilt? |
Originally posted by alexshine I will be moving in one week and was planning on modifying some bunk bed pieces to make a large shelf that stands in the center of the room. The projector will sit on top, with the rear end tilted up so that the lenses are angled downward. Will this work? I was just worried that the tilting might throw off something like keystone or geometry. The PJ is a Marquee 8111. I saw something similar to this in the manual where the PJ was on a rolling cart at about chest height, and the rear end was raised just slightly so that the lenses were parallel with the floor. In my setup the rear will be raised even higher. |
