How to mount my ceiling mount?
1724 Views 15 Replies 6 Participants Last post by  Dittoz
I'm using the Mustang MV-PROJSP universal projector mount. My plan is to simply mount it into one of the studs in my ceiling from above. The projector I have is an Optoma HD70. 2 questions.
1) What hardware should I use to attach the mount to the stud in the ceiling? This is a previously finished room, with drywall already up. And the ceiling is textured so I would love not to have to cut any kind of hole in it that would have to be patched later. Also there is no access from above to this room.
2) Does this projector have to be dead center in front of the screen, or is it possible to have the projector slightly off center and still achieve optimal viewing?
1 - 16 of 16 Posts
I have the Optoma H31 and I imagine the HD70 is much heavier than the H31. I just built a small 1/2" plywood base that I screwed into drywall anchors in the ceiling (5 of them -- 4 corners, one in center). Then I just screwed my PJ mount into the plywood. It's not going anywhere. Just make sure you use the metal drywall anchors and not the wimpy plastic ones.
You can mount it slightly off center and fix the image with the keystone adjustments. But if you use a method for mounting the PJ like I pointed out (or different but same idea -- not relying directly on a joist/stud) then you can mount it anywhere you want and make sure it's center (don't forget that the lens is offset from the center of your PJ -- I forgot and mounted the base in the wrong location the first time
Mike
See less See more
I had the H31 and recently purchased the HD70. They both weigh about the same, maybe a pound heavier for the 70. The interesting thing for me, that I thought I would let you know, is the HD70 and H31 mounted exactly the same way and in the same place without modification.
I used lag screws to mount it to the ceiling, but I had put plywood between the "studs in the ceiling" so I didn't have to search for the studs. It worked out well. I'm sure that drywall anchors will work, since the weight isn't that great.
A slight "off center" isn't going to kill the picture, but I would get it as close as possible.
Ken
All good ideas...and I appreciate the advice, thanks! The only problem for me is that I can't get above the ceiling to put a piece of plywood between the studs like you did. And while the projector isn't all that heavy, the mount is quite a bit heavier than I expected it to be. I really wouldn't feel comfortable with it just in the drywall with anchors. My joists run horizontal, so I could actually get it pretty straight with the screen, but I can only get two of the screws(bolts?) in the joists and then the corners of the mounting plate I would attach with anchors into the drywall.
So now my only remaining question is what bolts should I use to attach it into the stud? And I'm a complete DIY newbie so what drill bit? or just general instructions on attaching it. Thanks!
O O O
X O X
O O O
This is how my mounting plate looks roughly. I would attach the 2 X's with the bolts in the stud, and then the 4 corner O's with anchors in the drywall.
See less See more
hey gang newbie here...but I've been reading in here for weeks. now I just recieved my HD70 and the same mustang mount.... but I'm having a hec of a time trying to find "M3 " screws to go into the projector. No body at any of the hardware stores I've been into seem to know what they are. Maybe its a Canadian thing..but can someone please shed some light on this for me so I can enjoy my new toy...cheers
M3 is metric. They'll be in the specialty bins at your hardware store. If you have an Ace Hardware they're a lot more knowledgeable and have a better selection too.
3
I put my plywood on the drywall since I already had one layer of drywall in for the ceiling because it's upstairs and code required it to occupy the home (I built the theater later).
Here's a picture of what I mean:
Here's another shot:
One from the back (it's showing the exhaust vent and I haven't finished it off so it's a bit messy but should give you an idea):
I can get a better picture of the mount and board itself if you need it but I think you should be able to get the idea from these. Note that 3 of the sides of the plywood are not painted because a box will go around the PJ to hush it and point the heat to the exhaust vent in the ceiling.
Mike
See less See more
I attached my PJ mount using nuts and bolts to a decorative "plate" that I built using 3 pieces of MDF, then just attached the whole darn thing to one joist in the ceiling with 2 - 3" Zinc coated wood screws. The whole thing weighs probably 25 lbs,,, but 2 - 3" screws will be plenty to hold it up there forever. It's VERY sturdy.
See less See more
Originally Posted by maverick2 /forum/post/11671834
.... but I'm having a hec of a time trying to find "M3 " screws .... Maybe its a Canadian thing...
it's actually not just a Canadian thing, but a world-wide thing (save a couple of countries)
accts4mjs, why do you have a vent? Does the PJ give off that much heat that it affects the room, or is this a suspenders and belt approach?
See less See more
Oh yeah, totally. Without the vent my room goes up about 5 degrees easily. I was just shocked after I put the PJ up and turned it on. It's worse in the summer and not so bad in the winter. I think because we keep the house slightly warmer in the summer and slightly colder in the winter to save money. So the winter slightly colder turns into slightly warmer with the PJ on versus in the summer the slightly warmer turns into sweating like a pig
Mike
See less See more
Nice looking plate. I would definitely recommend something like that if you're not going to put a hush box around it (which I'm doing so I didn't bother finishing the edges of the plate).
Mike
Ok guys, great advice again. I got the mount installed in the ceiling. But obviously that universal mount didn't come with the M3 screws so I'm going to have to go out hunting for those this afternoon. Hopefully Home Depot will have them.
Next question is about the HDMI cable. I installed an electrical outlet next to the mount for the power source. But what should I do with my HDMI cable? Is there such a thing as an HDMI face plate? Where I can install a j-box in the ceiling just as I did with the electrical outlet? Or am I going to have to just suck it up and have a friggin hole in my ceiling for that cable?
Yeah, you can get hdmi face plates. Monoprice carries one right here:
You could also just put a plate in that has a bushing that will clean up the hole (I don't have a link for those, but I've seen them). You could also put some wire loom around the cable from the ceiling to the projector that's slightly bigger than the hole and then you'd not only cover it up but have a really cool looking effect with the wire loom (I did that for my ceiling hung surrounds and people comment on how cool the cable looks because it's thick -- eh, who knew that would be cool
Mike
See less See more
Dittoz,
You should be able to find a cover plate online, like this one.. http://store.pchcables.com/sipohdwhwapl.html
You guys are great, thanks! I'll see if I can't find a gray one, since that's the color of my outlet plate right now. Now I just have to fix one screw up. The outlet I installed is just slightly crooked. Most people wouldn't be able to tell, but it'll eat me up if I don't fix it lol. I hate to dig more holes in my ceiling but that's part of it I guess
See less See more
1 - 16 of 16 Posts
