Trying to get a remote to talk to my new TV and I was trying to follow the instructions at the site:
http://www.hifi-remote.com/manuals/OEM.shtml?Replay
I couldn't get it to work and was trying to undo whatever had been done to the remote before so I tried every clear command I could find.
I think I entered the disable Replay codes command 9-7-7. The manual says to reinstall the Replay codes you enter 9-8-7 and then after two LED flashes enter 0-0-0-1, but I get a long flash instead of the two flashes after that, indicating an error.
I noticed then that this was for the Replay 5000 series remote, yet my remote is from a 2000 series. Where can I find out the codes for the 2000 remote control?
-Randy
-Randy
