1 - 4 of 4 Posts
Hey guys, im about to buy a samsung 226bw lcd screen, and need to know if my video card will support the resolution of the monitor using 1:1 mapping.
The samsung native res is 1680x1050, and my video card supports resolutions up to 2080x1050 or something, does this mean i should be ok with the video card?
its an old geforce mx200, not for gaming or htpc.
thanks
There are certain patterns you can download which will show you whether you're getting 1:1 or not.
I'd suggest getting PowerStrip and creating a custom resolution of 1680x1050, essentially guaranteeing you'll be getting 1:1 mapping.
Check out the Powerstrip ultility, this can be useful if your monitor does not have a "complete" EDID information.
However the first step would be to download the latest drivers for your graphics card (ATI or NVidia sites), as pointed out below it is a fairly common Widescreen resolution.
Yours is almost a 16:10 aspect ratio screen, so even with 1:1 mapping 720p (1280x720) will have black bars, and depending on your setting be scaled to fit your width (1680x945 whilst maintaining 16:9).
Generally VGA offer most hope of 1:1 mapping on LCD's. Especially so on HDTV's (1366x768), where the DVI/HDMI input is expecting 720p/1080i-p...........unless its a 1080 screen, where HDMI is normally more likely to give 1:1 mapping.
Also 1:1 mapping is only half the battle, do not forget the benefit of 24/48/72Hz refreshrates with HD sourced video.
Check out the ntest utility, and moninfo ultility to help you in your quest.
First off, that is a computer monitor, so it should work with a computer. As long as you have the latest drivers, you should be fine since that is a common widescreen resolution.
1 - 4 of 4 Posts
