Status
Not open for further replies.
1 - 3 of 3 Posts
HS20 owners.....how did you test for Pixel/Panel Alignment?
What program did you use, if any?
AVIA test screens?
Or does the HS20 have a convergence grid, like CRT projectors?
Thanks in advance,
Phil
The easiest way is to bring up the focus/zoom display (with the grid activated). There will be white (broken) borders on the screen.
If you have perfect convergence, every white hash mark will be white. If there is some mis-convergence, there will be red/green edges on all or some of them.
A recent poll determined that it is fairly common for 1 side of the screen to be out about 1 pixel. This should not affect PQ. If it is out much more than that then you might want to object to the quality of your unit.
gp
1 - 3 of 3 Posts
Status
