z558 upgrade status?
I just picked up a new MOBO to give my z556 some newer life.
I decided that I didn't want to gamble with buying a z565 MOBO and not have the HDMI sound work so I am going to carve out the back of the case to fit a standard I/O plate for a standard uATX MOBO.
It might be a little while but stay tuned.
Hi Hazardsneon, How is your upgrade progressing? I am wondering because I'm considering performing a similar operation on my HP z558 Digital Entertainment Center.
Some recent history... the power at my house recently went out and back on, after which my z558 would not power on. Having replaced my power supply multiple times in the past, I assumed the ThermalTake power supply was to blame. ThermalTake sent a replacement, but when I hooked it up, it still would not boot. After some isolation, I discovered the fault was with the motherboard... after installing a refurbished PTGD-LR motherboard which I purchased from Ascendtech for $19.99, my z558 is back in operation.
While I was busy isolating the problem, I learned a bit more about the innards of my z558. I'm considering doing like you and cutting the back of the case to fit a standard microATX I/O shield so that I can install more modern (and faster) components. I'm more interested in performance and future-proofing than expense at this point.
My z558 is installed in a "theater room" in my home. It stays powered on continuously. It is running Windows 7 32-bit and I have a Blu-Ray driver/burner in it. Here are some of the functions it performs:
(1) I have a personal/family web-site that it serves, thus allowing me to access content from anywhere with Internet access. We keep our family's media (i.e. family pictures, family videos, etc.) on it.
(2) It is running Embedded Automation's mcontrol software to perform home automation (I have a variety of home automation devices, including Insteon switches, an IP camera, etc. in my home).
(3) We have 5 XBOX 360s in our home that we use primarily as Media Center Extenders to access content from the z558 from any television.
(4) The z558 is connected to a projector/AV stack that allows us to watch movies and TV in the theater room. I did a bit of customization such that we can insert a disk (DVD or BluRay) in the z558 and it automatically turns on and configures the projector and AV receiver, dims the lights, makes an announcement regarding the movie is starting and turn off your cell phones (
), plays a brief customized introduction, and then plays the inserted disc.
(5) I use the personal media drive slot to perform backups... switching drives monthly such that I always have a backup stored in a fireproof vault that is no older than 1 month. For me, this is an important feature of the z558.
Here is what is in my NewEgg shopping cart (i.e. what I'm considering buying):
GIGABYTE GA-Z170M-D3H (rev. 1.0) LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard ($114.99)
Intel Core i7-6700 8M Skylake Quad-Core 3.4 GHz LGA 1151 65W BX80662I76700 Desktop Processor Intel HD Graphics 530 ($329.99)
G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform / Intel X99 Platform ... ($62.99)
Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM ($6.49)
I'll probably just use a Dremel to cut the back of the case.
At least at first I plan to stick with the current operating system (due to time constraints in dealing with my customization and also I'm not sure whether all of the software/drivers I use having 64-bit equivalents). In the future I might upgrade to Windows 8.1 64-bit, if performance/capacity seems lacking. The memory is really overkill, since I think I'll only use half of it while I'm still on a 32-bit operating system.
I realize that most people would prefer to just switch solutions altogether, but I've never been accused of being like most people.
Anyway, since you've been down this road, I'd appreciate any insight you may have... if you learned anything by doing your upgrade, or having any suggestions regarding my proposed new components.
Arden
