Yes you can use it instead of phone line. It will also be used for DoD.
Originally Posted by hoops10 /forum/post/12822762
Do most people even have their HR21 connected to the phone line? Or do you all just leave it not connected?
Originally Posted by markrubin /forum/post/12832721
I have a slightly different understanding of this (based on my HR20's)
-Phone line is only necessary if you want to order Pay per View using the remote: otherwise no need to connect it
-Ethernet is used for VOD: it does not replace the phone line to buy PPV using the remote: otherwise no need to connect it
- HR20's will hang up during booting unless the Ethernet connection is unplugged: plug it in after the reboot is complete
Originally Posted by CKNA /forum/post/12845040
No need to have phone line hooked up for PPV anymore.
Ethernet is used for VOD and PPV ordering.
My HR20's or HR21 do not hung during boot up with ethernet pluged in. If it does that means your DVR is broken or something is wrong with the ethernet connection.
I suggest for anybody with questions about HR20/21 to visit dbstalk forum.
Originally Posted by hoops10 /forum/post/12851191
Is there any way to have a HR21 and also use OTA HD channels? I have been told that the HR20 (which I believe has an OTA tuner) are hard to impossible to find. Also one other question, I spoke with a DirecTV installer today who told me that by 2009, all OTA HD channels will not work. Any truth to this?
