i can't seem to display movies in their correct aspect ratio.
i don't actually seem to own any 1.78:1 movies (anyone recommend one?), but i do have a number of 1.85:1 and 2.35:1 dvds.
ignorance is truly bliss because now i'm really frustrated. the picture seemed a little off to me, so i actually pulled out the tape measure and i can't get 1.85 movies to display at the proper ratio. nor can i get 2.35 movies to display correctly.
i'm using the hs-10 ceiling mounted in "full" wide mode, projecting onto a 92" diagonal da-lite model b (16:9/1.78:1).
i've tried all the wide modes. even the full and normal through modes aren't yielding the correct aspect ratios.
for example, using Last of the Mohicans, which is 2.35:1
- full: 2.8:1 (80x28.5)
- normal: 2.14:1 (61x28.5)
- wide zoom: 2.75:1 (80x29)
- zoom: 2.16:1 (80x37)
- subtitle: 2.22:1 (80x36)
- full through: 2.87:1 (46x16)
- normal through: 2.15:1 (34.5 x 16)
Edward Scissorhands (1.85:1)
- full: 1.77 (80x45)
- normal: 1.35 (61x45)
- full through: 1.76 (46x26)
- normal through: 1.32(34.5x26)
Amelie (2.35:1)
- full: 2.16 (80x37)
- full thorugh: 2.19 (46x21)
Dune (2.35:1)
- full: 2.85 (80x28)
- full through: 2.87 (46x16)
my measurements may be off by a half-inch here and there as i was measuring alone. but i did double and triple check, so nothing is grossly off.
for instance, on a 16x9 screen, oughtn't i see small black bars across the top and bottom on a 1.85x1 movie? edward scissorhands fills the screen perfectly, which while nice, seems off according to the numbers.
the 2.35 movies are really off though.
any ideas how to account for the disparities? can anyone else confirm their own ratios?
fyi: i'm using an apex ad-600a dvd player with component out to the supplied sony multi-cable.
thanks in advance!
Amelie (2.35:1)
Dune (2.35:1)
thanks in advance!
