Originally Posted by TwilightZone /forum/post/13002070
I read the polarizer replacement thread and it doesn't seem to bad. Was wondering if anyone had ever tried a prism block since that is my other option (I have a spare)?
JDLIVE: How long did it take you to swap out your polarizers? Anything to note that isn't in the polarizer thread already?
Well, since I've taken my HS10 apart a few times now, I could probably do the swap in literally a couple of minutes.
But if you've never poked around inside one, you're going to want to go more slowly and be careful. Some of the connectors you need to take apart aren't exactly sturdy. You also may have to do some trial and error to get the new polarizers facing the right way, there's no marking to tell "front" vs "back". Also, make sure to reconnect everything, I thought I had fried mine because it wouldn't turn on the first time I put it back together.
Turns out I had just forgotten to reconnect the sensor for the remote. Phew!
As for the prism block, all I can tell you is it would involve even more disassembly. I took about as much apart as I was comfortable doing and would have had to go further to get to those parts. Of course, if it's shot it's likely worthless anyways, so it's not a big risk I guess.
