Hi,
I am running a HTPC with my HS10 with 1:1 mapping @56 Hz refresh rate. I have seen that if you observe closely all movies stutter while playing especially when the camera is panning. On further investigation on AVSFORUM, I found out that it is most probable due to the 56 Hz refresh rate which is not a exact multiple of 24 fps at which the movies play at. I want to know if there is any method to fix this. I have seen some people using RECLOCK - will this program be able to fix the stuttering.
bye
bye
