Status
Not open for further replies.
1 - 1 of 1 Posts
The HS10 has several modes selectable using the Wide Mode button on the remote.
I am programming my MX-700 universal remote and I am having some difficulty trying to decide how to program these modes. I take it there are no discrete codes for for the various modes, right? I could use a macro, but the Wide Mode button always defaults to the last mode selected on the first press. This makes programming a macro for this very difficult. To complicate matters, the Full Through mode (or one of the modes) does a search on the input causing a long delay.
The Wide Mode can be set by Input mode on the Menu screen and I have thought of using that. My Inputs could be User1 Normal, User2 Zoom and User 3 Full.
There seems to be limitations no matter how I do this. Has anyone come up with a way to handle this using a universal remote?
Also an explanation of the differences in all of the Wide modes would be helpful. Some of the Wide modes are obvious, but others are not.
Gary
1 - 1 of 1 Posts
Status
