Status
Not open for further replies.
1 - 4 of 4 Posts
I'm going to be getting the HS20 and was wondering about the dvi input. I will be getting direct tv HD and wanted to make sure that the dvi cable will give me a uncompressed signal. I have to get a 30+ foot dvi cable and wanted to make sure I get an uncompressed signal. Any information would help. Also, what is the HDMI input for? Is it for future products or are there high def recievers that support this? Thanks
DVI / HDMI are the same except that HDMI can pass audi and you can have longer runs in DVI. There are few products on the market now that have HDMI outputs on them but there are many on the way.
cobatlcable.com has the best 30' cable DVI cable i have seen. my current setup uses that from my time warner HD box. picture looks very nice. others have noticed sparkles with some other brands, be careful which one you buy.
1 - 4 of 4 Posts
Status
