Hello everyone, before I start let me say thank you to Mikeyboy for his help.
I read the values of the power connections on my HS2000 motherboard with my multimeter. All connectors read zero voltages. I wanted to verify if the ceramic fuse was blown so I temporarily attached a thin wire from the top of the ceramic fuse to the bottom and turned on the unit. The HS2000 turned on (the unit was not turning on - additional information http://www.avsforum.com/avs-vb/showt...hreadid=251201 ) and I quickly turned it off. The result verified the fuse was faulty.
I decided to unsolder the fuse by placing the soldering iron on the connections between the fuse and power supply motherboard (two spots) while removing the ceramic fuse with needle nose pliers (ask someone to help you). I purchased Fuses (Radio Shack 3.15Amps 250Volts - item#270-1065) and just in case the fuse blows again I purchased a Fuse Holder (RadioShack item# 1270-1238C). Total cost was $4.13.
I am not an expert on soldering so it wasn't a beautiful connection, but it worked and now my HS2000 is working condition thanks this forum.
zenshikai
zenshikai
