My HS51 has developed what I can only describe as a "blue corner". The lower right corner is more intensely blue than the rest of the image, which still looks fine. This started about 2 weeks ago as a small spot on the left edge in the middle (top to bottom) of the image. It has evolved and changed and now covers a triangular section of the lower right corner. I thought it was probably the bulb, which has about 1.5K hours on it. I ordered a new bulb and I just installed it. The blue corner is still there.
I know projectors used to get "dust blobs". Is it possible that a dust-blob is causing this problem? If so, how do I clean it out? I replaced the filter at the same time I replaced the bulb. The old filter didn't look too bad and it only had about 600 hours on it. I've replaced the filter every 1K hours as recommended.
My projector has a total of about 3.8K hours on it. Is it possible that an LCD panel is bad?
Any thoughts? TIA.
Craig
Any thoughts? TIA.
Craig
