Actually it will go down to 16Hz even though the Hsu documentation states 18Hz. All you have to do is plug one of the ports with the plug Hsu provides and flip the switch on the back to the 20Hz setting.
Originally Posted by ransac The HSU is smaller and lighter and most people would say it is more musical. Either is a good choice. Both have variable tuning. The SVS has more tuning options, but most would say to stay away from the 12Hz tuning as it blocks too many ports which can result in port noise and it lowers the overall output too much. If you don't listen real loud, this is probably not a problem. The jury is still out on the new NSD driver. There haven't been any comparisons to the ISD driver or pro reviews done yet. SVS claims it is an improvement and I don't think they would make that claim if it weren't true. But.... The Hsu allows you to add the turbo for ~$120 which is supposed to get much more output at the tuning frequency. I haven't seen that it adds much above the tuning freq. For $200 more you can get the SVS PB12-NSD/2 which has mondo output. This adds more output across the whole sub range. So if you want max output, consider adding the Turbo or getting the NSD/2. If you don't want the higher SPL levels, go with the Hsu sans Turbo or the PB12-NSD/V. I know SVS is, and have heard many say Hsu is, a quality company to work with. |
Originally Posted by OvalNut I say this thread never makes it to 50 posts before it mysteriously disappears... Tim |
Originally Posted by Reginald Trent That can probably be explained by..... Hsu is a AVSforum sponsor and I'm sure they don't like paying for bandwith that tells people SVS is better than their subs. |
Originally Posted by ransac So is Velodyne, but how many Hsu is better then Velo threads get deleted. Besides, where does it say SVS is better than Hsu or any other sub in this thread? |
Originally Posted by Reginald Trent Not likely since both are sponsors that fact alone negates your premise. Surely you two cannot be so naive to believe a non sponsor has the same say so over this forum as a sponsor? Why else would post marginally critical of Hsu mysteriously disappear so often? |
Originally Posted by DrewB Reginald, your fanboy act is growing old. Why don't you run along to HTF so that you can pimp SVS subs 24/7. |
Originally Posted by golflover123 Hi All Newbie Here, I Have The Ascends And The Hsu Vtf3 Mk2 On Back Order And Have Been Reading A Lot About Being Able To Get The Sub Down To 18hz In Max Extension. What Does This Mean Exactly? Do I Need To Order It A Certain Way Or Set It Differently? Also I Was Thinking Of Going With The New Svs Pb12 Nsv/v Instead...any Opinions? Thx, Matt |
