What makes you think designers have to be living in Tampa? The designers I have built plans from never visited the actual job site, they can work from photos, measurements and remote conversations with you about your goals and vision.
On subs consider HSU, SVS and if the budget permits Seaton. The look in your inspiration photo can easily be achieved with the fabric track system from Fabricmate.com or other DIY methods. I would encorage you to consider using darker colors near the screen due to reflections.
