LIVE: AVSForum Tech Talk Podcast with Scott Wilkinson, Episode 5 Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally Posted by asolutions /forum/post/0
You definitely need acoustical door seals on the door. You can see light coming in underneath the door therefore sound will come in as well. A one percent opening around the door can let in up to 50% of the noise.
The last post suggested door jambs and an automatic door bottom - which is correct. However I would add astragal seals - since this is a double door you would need to seal the point where the doors come together. Also since you have carpeting in the room I would add a threshold for the automatic door bottom to land upon - that will provide a better seal for the automatic door bottom.
Feel free to call me with any questions at 1-800-782-5742 or visit my site for more details http://www.acousticalsolutions.com
By the way your home theater looks good. Nice job.
Dave Ingersoll
Originally Posted by speedboy /forum/post/0
I will check it out. How about for the walls. My wife says she could hear it all throughout the house. Any suggestions
Originally Posted by Terry Montlick /forum/post/0
To make it quiet, a home theater room needs special sound isolation construction when it is built. These include walls with more thickness (staggered stud or double stud), multiple layers of sheetrock, ideally with viscoelastic damping layers (e.g. Green Glue) between them, or resilient mechanical isolation (e.g. RSIC-1 clips).
Can we assume from your question that your room has none of these? Unfortunately, extremely effective sound isolation is difficult to add to a room once it is built.![]()
- Terry
Terry I did put in Sound Isolation. I used Dynil. Here check it out http://dynamat.com/download/arch/2038_Dynil_Lit.pdf The sales rep told me it works like 11 sheets or sheet rock.
I don't know if that that is true. Any other Ideas, maybe padding to the walls?
Originally Posted by Randito3 /forum/post/0
I still need to treat my door to my theater. It's the only thing that lets sound in or out. I need to do something soon.
