I would like to start upgrading by maybe buying 1 a month.. i will be buying the polk monitor speakers off new egg.. only thing that probably wont be polk is the sub which will most likely be purchased last.. my question is what should be upgraded first and what should i buy.. here are my options
Monitor 30s or 40s to replace fronts... no matter which is bought, when i purchase towers, the 30s or 40s will be used as surrounds
or hold off on the bookshelfs and purchase a CS2 first to replace center... basically i would like to know which would be more beneficial to replace first since this upgrade wont be done all at once
and is it worth the extra 20 - 30 bucks to get the monitor 40s over the 30s since they will end up as surrounds
