41 - 60 of 229 Posts
Discussion Starter · #41 ·
If you go with RayGuy's TV mount suggestion, you might consider the NHT SuperOne or C3 or Ascend CBM-170 speakers because they already have threaded inserts in the back. You would probably need to drill additional holes in the VESA mount or add a custom plate to match the speaker inserts, but at least you would not have to drill holes in the speakers.
o wow that’s perfect!
i really don’t wanna drill into the speakers so that’s great info!
as of now roughly 1k with wiggle room, i’m fine leaving the center out for now to get it next month or 2. maybe another $500plus then
not at home but i’m pretty sure the top 2 cubby shelvesare 9.5ish tall
however if i wall mount them i was hoping to find a telescopic or long arm mount for the speaker that will actually sit the front edge of the speaker past the front edge of the left and right entertainment towers. so i would assume that would be best-ish since it would not bounce or reflect off the side kinda like this but a longer arm
Those decorative cabinets look really nice, but have you considered just removing them (and maybe putting them somewhere else) and putting two bookshelf speakers on short stands right alongside the TV?
It wouldn't look as nice, but then again, it's not going to look very nice if you have speakers telescoping way out from the walls, either.
To sell the idea of getting rid of the cabinets, you can get bookshelf speakers with furniture-grade cabinets. The Polk RTi cabinets look really nice IMO for example, nice curved wood veneers. Some of the Wharfedale Diamonds, too.
The price will be a bit of a stretch, but Aperion Audio makes some really beautiful speakers and all the reviews I've read say they sound great. Sometimes they do closeout deals or sell refurbished stock and that can get the price down.
I don't think any of these options will sound better than e.g. the Ascends, but they'll look good and get you 80% of the way there. The Ascends are not good-looking speakers.
RSL has good looking speakers. They should be on the short list.
That said, from an aesthetic perspective, speakers on stands or tower speakers just outside the cabinet would present a far better look than the extended wall mount scenario you are considering. For an inexpensive (relatively) entry into this realm, look at Polk S55 and Q Acoustics 3050i. For bookshelf options Polk has the S15 and QA has the 3020i or the Concept 20. If sleeping in your own bedroom is a priority in your life, you might give some consideration to this advice ...
Sounds like rbfastback is running up against some space constraints to even place a subwoofer to the left/right of the entertainment center, much less two tower speakers and a subwoofer. Dunno.
Although with two tower speakers, you might not need a subwoofer. I have two towers and I think my setup sounds good. It only goes down to 40Hz so it's not shaking my house's foundation, but lots of nice sound systems only go down to 40Hz.
If you're going to have each tower a couple feet away from the TV though, I think a center channel becomes a necessity...
I'm inclined to suggest getting rid of the top shelves in those decorative cabinets (not sure if they're removable??) and putting bookshelf speakers in those spots, but then you're really limiting your options by cutting out any rear-ported speakers. The NHT SuperOnes should fit nicely with that shelf removed...
Good observations. The NHT and RSL options are sealed / front ported designs, so they would be 1a and 1b on the shelf-placement options list. Agreed about the necessity for a center channel if the speakers are so far apart. However, the center speaker needs to be at the front of the cabinet, not the back (as the current one is shown), otherwise the early reflections will ruin the dialog and generally muddy the sound. He might even consider a three channel passive soundbar at the front of that cabinet, if there is no room for two speakers and the sub in the front of the room.
@rbfastback ... what is the height measurement of the opening of the shelves that are on the same level as the center channel speaker? Seems to me that the most cost-effective solution to all your problems is to put speakers there. Then, the sub can go anywhere it will fit.
Good observations. The NHT and RSL options are sealed / front ported designs, so they would be 1a and 1b on the shelf-placement options list. Agreed about the necessity for a center channel if the speakers are so far apart. However, the center speaker needs to be at the front of the cabinet, not the back, as the current one is shown, otherwise the early reflections will ruin the dialog and generally muddy the sound. He might even consider a three channel passive soundbar at the front of that cabinet, if there is no room for two speakers and the sub in the front of the room.
RSLs are sealed? I'm not familiar with their offerings although I know they have fans and usually get good reviews.
Looking at their web site I'm only seeing offerings that have a "compression guide" enclosure which looks like a simplified folded horn. Looks a lot like Atlantic Technology's "H-PAS" enclosure actually.
Frequency response of one of their bookshelf models looks a little choppy?
https://www.soundandvision.com/content/rsl-speakers-cg3-51-speaker-system-review-test-bench
Nope, misspoke (since edited and corrected).
Discussion Starter · #48 ·
screw it i sleep in my own room anyway haha since i’m usually up till 2-3am and she’s goes to bed at 9 then up at 6..
i snore really loud too.
when i do get the center channel it will be pulled forward to the edge, i just have to adjust the mount on the tv for more space.
that center sounds bar was a super cheap gift that cost nothing and i didn’t want them to feel bad so i just put it there, the tv speakers are better lol.
all shelves are 9.5” openings but read the update below
UPDATE:
everyone is definitely right (and EXTREMELY helpful)
trust me those tall decorative cabinets aren’t going anywhere right now and the shelves are not adjustable or removable and i really don’t want to limit the speaker selection by size or rear port or use towers for the main reason of getting more for my money with bookshelves ( i really like the tower look)
i told her this was just a small/inexpensive project (under 800-1000) since till the kids are in school i stopped working.
SO i talked to my her about it an just told her we gotta move some stuff around cuz the wall mounts (no matter what if we keep our decorative entertainment center) will not look good aesthetically and sound as good as it could.
•so i’ll have room for left and right bookshelf’s WITH STANDS on the sides of the tall decorative cabinets!
then the sub i’ll figure out next.
either right side corner or to the left of the left bookshelf.
so no more size restrictions on what bookshelves, and yes the ascends are not the most beautiful and that was pushing me more towards the others lately.
i was looking at the sierra 1’s but they are definitely more and the center channel for those would not work cuz my ocd couldn’t handle a non symmetrical sideways speaker
( i want the center to look similar to most long short centers, like the cmt 340)
Discussion Starter · #49 · (Edited)
ok so i absolutely love the all the comments and reviews on the ascend cbm 170 and 340, i just wish they looked a bit better (still may get them tho, looks aren’t everything but it’s a strong factor still) but i don’t want the sierra 1’s since the center won’t work/don’t like in my setup. idk why they make it like a sideways bookshelf....
what do u guys this the closest match to the ascends?
from all of my reading and reviews id say the kef q350 are very close to what i’m looking for and my second favorite so far (without listening)
i think they are better looking too
my list in order is:
-Ascends CBM 170( aside from listening i’m thinking they will be perfect aside from not looking very good)
-KEF Q-350 ($500 open box)
-Infinity Reference r162
and the rc263 center($400 shipped)
possibly polk s20’s for looks over infinity ref 162?
i think the svs prime definitely look the best and will match best but i keep reading controversial comments.
too bright, harsh and cause fatigue?
can anyone confirm this or say what they think of them?
i want them to work the best for visuals but it’s not more important then the quality of sound i want for ht.
I think they don't really "make" it, they just take a regular Sierra bookshelf and turn the tweeter 90 degrees, for people who don't want to spend $1000+ on the Sierra Horizon. EDIT: A solution to the asymmetry is to put the speaker grilles on... :)
I don't know if the KEFs would be similar to the Ascends but they do measure very well. They'd be on my short list too if I was buying new speakers.
https://www.stereophile.com/content/kef-q350-loudspeaker-measurements
That looks like the refurb price. If you're okay with refurb it does look like you can save a stupid amount of money. (Also these speakers will sometimes go on sale for prices that aren't much higher than these refurb prices, but it's a pain to wait for a sale.) If you like the idea of tower speakers and how they look, maybe get a pair of R253s instead of R162s for only $200 more... and not even that much more, considering you wouldn't have to buy speaker stands for them... and the towers put out enough bass that you wouldn't have to sort out a subwoofer immediately. Then again, if you're just auditioning the speakers and there's a possibility you might return them, it's going to be a LOT easier to return bookshelf speakers vs. towers...
I've only read good things about the Polks but for some reason I suspect they might be good for their price, whereas I think the Infinitys are probably competitive with any speakers at any price. The reason I say this is because data has trickled out of Harman about a couple of previous models of Infinity (Interlude IL 40 and Primus P360, I think) that show them beating vastly more expensive speakers in double-blind testing and having nearly ideal spin-o-rama plots.
This reviewer gave them a pretty good review but not amazing, I'd be more inclined to try the KEFs, Ascends, or Infinitys.
http://noaudiophile.com/SVS_Prime_Bookshelf/
If you're thinking about looks to the point where you're considering moving up in price range to Ascend Sierras, etc., you could just buy a pair of Revel M16s and call it a day. :)
Discussion Starter · #53 · (Edited)
i thought so too about the price being so low but didn’t see anything saying refurbished on the harmen or infinity site, same price on both sites
https://www.infinityspeakers.com/re...REFERENCE 162_color=Black-USA-Current#start=1
https://www.harmanaudio.com/speaker...vent=ac4accc2804f11e9809a03ea0a24060e&start=1
just says sale price
i looked all over the web for the r253’s and they all say sold out or unavailable.
i see the r253’s tho
i may take a little more time to consider how important looks are.
i never considered towers since i am always reading about how for the same money bookshelf’s will get you more. however towers are sexy
Discussion Starter · #54 ·
Inexpensive and pretty? You're back to RSL and Q Acoustics. And, yes, the SVS Prime can be fatiguing, according to many reports on this site and elsewhere.
https://thewirecutter.com/reviews/best-bookshelf-speakers/
The KEF Q350 looks great, but how much is the matching center channel? ... annnnnd that eliminates it from the competition.
yeah your right, i just need to figure out my planed future expenses into this project, i don’t mind paying for an expensive center down the road. i’m sure ill be fine with the BS’s and a sub for a month or so.
Discussion Starter · #55 ·
links aren’t loading in the forum but if u go it infinityspeakers.com or harmenaudio.com and search them u can see they are $200.
either way i think i’m definitely going to order a set of LCR infinity ref.
that’s so cheap and i can use them in my main room till i pick something else or just stick with them till i’ve learned enough to truly appreciate the next level up
Good catch on that price. At those prices they're a steal.
I assume you meant you couldn't find the R263s... I would say just get the R253s, that's what I did. I had the money for the R263s but they're bigger and heavier and the only difference is that they give you 3 extra Hz of bass extension. Not worth it IMO. I have an open floorplan with really high vaulted ceilings and the R253s have no trouble filling my space.
That's true that for the same price, you can get a better bookshelf, but at half off, seems like you might as well go for the towers!
Discussion Starter · #57 · (Edited)
ok cool, yes i meant the R263 can not be found.
and yes i’m going to get the 253’s just because that’s a great price!
would the R162 BS’s be good for rear L/R?
and lastly would the RC252 or RC263 better fit the towers?
EDIT:
i figure the 3way with lower Frequency Response vs 2way is much better but i’m probably going to get the rc253 for its size
Discussion Starter · #58 ·
i’m my shopping cart i have
-1 pair R253 towers
-1 RC263 center
-1 pair RS152
should i get anything else since matching in the future may be impossible at this price?
ill get the svs sub next month
i hope the r253 has as great sound measuring as the r263’s (maybe not a proper term)
will the RS152 be a good surround vs the r163? more compact and a better shape for visuals i thought.
i’m always reading the rear isn’t as important
Discussion Starter · #59 · (Edited)
ordered:
the infinity reference
-R253 towers
-RC252 center
-RS152 rears
$783 shipped
edit: i’m ordering the svs pc-2000 in a few weeks
called infinity and they have amazing and free return policy even with the towers.
i dont think i will be returning them at that price anyway tho and i’m sure from everything i can find on them ill be very happy.
i am still going to continue with my current short list adventure and auditions of bookshelf’s tho since eventually i’ll put these in the other room when i have more $ for a better looking living room setup.
i haven’t even got the system yet and i already want to have more.
