Status
Not open for further replies.
1 - 4 of 4 Posts
O.K. I have been doing my homework. Would someone kindly double check my math. I am new to this whole front pj thing. You guys are always such a great help. Assume the HT1000, 104 inch ceilings, 80 x 60 4:3 screen.
I'll have 5 1/2 inches for the mount to the middle of the lense
12 inches to the top of the screen or 42 inches to the middle (same)
26 1/2 inches from the bottom of the screen to floor. That gives me 56 1/2 from the floor to the middle of screen (maybe a little high, but oh well)
I'll be able to have the lense 130 1/2 inches from the screen (that's with 4 inches of space behind the pj. That's enough since it vents to the side and front, right?)
How does everything sound? Your help is really appreciated. I don't know what I would do without this forum! :)
Gary
Discussion Starter · #3 ·
Thanks darnott! This was the very guide I was using. I guess I am so dense that I was wondering if you guys could make sure I was reading the installation guide correctly.
1 - 4 of 4 Posts
Status
