Status
Not open for further replies.
1 - 5 of 5 Posts
Banned
Anyone figured out a clean way to control the power on and off functions with a universal remote? It's not all that easy to generate a 2 second ir blast in a macro to turn the projector on. For off I'm ok with the no signal for 5 minutes turning it off if I have to live with that..
TIA
Floyd Pierce
Banned
Discussion Starter · #2 ·
Well to answer myself, the 2 second blast from my MX-700 works ok. I think it's just going to take a multiple repeat of the power on/off code in any macros.
I do not want to alarm you, but are you talking to yourself? In public?:D
1 - 5 of 5 Posts
Status
