No matter what type of connections I try I cant get output from the sub. I sent PMs back and forth with a few guys on here and appreciate their time and advice but still have not found a solution. Wired the HT18D2 to 4 ohm load and want to run the inuke3000dsp in bridged mode with a limiter of around 1100W. Inside the box I have the sub connected to the +1 and +2 terminals on the speakon connector which are of course marked. On the speakon cable itself, there are no markings on either end so I really don't know how to know what configuration I'm in. I was under the impression that I wanted both ends of that cable to also be +1 and +2. I've tried every possible series of configurations and I can't get any output from the sub. What should I try next?
The inuke3000dsp is set to bridged mode.
I used a 9V battery and tested the end of the speakon cable that goes into the amp and when the + and - terminals of the battery are hooked up the subs cone moves in the correct direction. I did this test to rule out the possibility that a wire came loose inside the box and to ensure polarity was correct.
Which direction should I move in next fellas?
