Hi guys,
after a lot of testing I have found that I cannot right now get the HT300 Plus to work properly at either one of the NTSC film ( multiple of 23,976 or if you use reclock 24 frames/s ) refresh rates although it is very easy to set up using the DVI port and it will sync very well at those settings. Those are my problems, maybe you have similar problems or can help me with exact Powerstrip timings that will help.
At 72Hz or 120Hz, the HT300Plus will sync fine without any problems but then, during playback I see tearing all over the place. I ran the reclock tearing test but even without it I can see heavy tearing all the time.
This does not happen at 50 or 60Hz .... those timings really work very well with the HT300 Plus.
At 48Hz tearing is not an issue so I should be happy BUT .... unfortunately at this refresh rate I see horizontal wavy lines in darker areas of the picture. It looks like flickering which caused me headaches at first but after careful experimentation I found out that this flickering only occurs between 47,5 and 48,5 Hz refresh rate. Playing around with the other porch settings did not help at all.
One can see this flickering by using the 20IRE grey test pattern on the AVIA disc or by setting the Windows XP background color to a dark grey (on the scale from 0 to 240 it would be 38 in my case)
This flickering is VERY visible in Lord of the Rings for instance which has a lot of dark areas.
As of now I don´t know if this flickering is caused by the videocard or the HT300Plus, the tearing is definitely an issue with the HT300+ although maybe it could be influenced by using different Powerstrip settings ?
I have written Sim2 tech support, but maybe you can help also. As for the flickering issue ... I will try another video card soon just to make sure.
My system configuration:
Sapphire Atlantis 9000 Radeon card
Catalyst 3.2 drives
DVI out to HT300+
HT300+ Version 2.13
Thanks for your help !
midiboy
Catalyst 3.2 drives
DVI out to HT300+
HT300+ Version 2.13
midiboy
